新完成的USB-DAC,請大家鑑賞,並指教!
文章Peleus 發表於 週五 6月 20, 2003 10:51 pm
呼~~~終於完成啦!過程雖不算千迴百轉,但對我這個大菜鳥來說,也是一個不小的考驗啦!請大家看看!並指教! :ho:
http://photo.pchome.com.tw/s02/peleus/book1/
追求極緻,絕不妥協!
如果錢夠的話....呵
Peleus
文章: 277
註冊時間: 週二 4月 22, 2003 9:27 am
來自: 台灣,台北
文章lifaung 發表於 週五 6月 20, 2003 11:00 pm
好棒,就剩下裝箱摟
不過為什麼不將之前敗的黑盒子用上去阿???
耳擴主力機:惡搞版LCKING CLASS A 1W+1W
工作處主力機:PCM1794 Upsampling
耳機:K501,K701,Music1,SHP1000
lifaung
文章: 1637
註冊時間: 週日 1月 06, 2002 11:21 am
文章FireDragon 發表於 週五 6月 20, 2003 11:04 pm
加油,剩機箱了.
使人前進腳步不是希望是意志
使人停止腳步不是絕望是放棄
FireDragon
文章Peleus 發表於 週五 6月 20, 2003 11:14 pm
Lifaung兄∼
因為〞聽說〞Rifa比較好聲啦!加上手頭有,所以就試試囉!
不過考量裝箱的難度(因為交連電容突出PCB板,會讓USB接頭無法突出箱外),最後也許會換Blackbox,也不一定! :eeh:
請原諒新手的〞猶豫不決〞! :haha:
追求極緻,絕不妥協!
如果錢夠的話....呵
Peleus
文章: 277
來自: 台灣,台北
文章FireDragon 發表於 週五 6月 20, 2003 11:32 pm
Peleus 寫:請原諒新手的〞猶豫不決〞! :haha:
:ho: 想太多了吧.
使人前進腳步不是希望是意志
使人停止腳步不是絕望是放棄
FireDragon
文章Tux 發表於 週六 6月 21, 2003 1:53 am
Peleus 寫:Lifaung兄∼
I love BlackBOX more than Rifa :lol:
8) 8) 8) Very Beautiful! All Holco :mad: ELNA :mad: :mad: LT Regulators :mad: :mad: :mad:
Which type of diodes are you using ?
Maybe you can try to get some ultra fast /soft diodes..
this can give u even better sound quality...richer sound :ya:
The two small 10uF next to the big DC coupling cap belongs to analog part... I do think use ELNA/Blackgate would be better than OS-CON
World is analog, digital is famous. (failmos)
Tux
註冊時間: 週五 4月 11, 2003 12:05 am
來自: 香港特別痕症區
文章steel 發表於 週六 6月 21, 2003 2:33 am
用料真補... :)
快試試聲音如何..???
steel
RS2
RS2
文章: 3142
註冊時間: 週日 3月 09, 2003 3:04 pm
文章Peleus 發表於 週六 6月 21, 2003 8:55 am
To Tux~
About the Diodes, I do not know the type, but the sales said it is ultrahigh speed in 35ns. I heard that the higher speed, the more pure power. That's why I try it! For avoiding the opening-closeing noise from the diodes, I used the Philips MKP cap. I would like to here your suggestion of the type of diodes. I do not know well about the relationship between the diodes and the quality of sound.
The regulators in digital power source is LM, not LT. I once try to buy some LT regulators, like LT 1086, from digikey, but it cost too expensive, so I give up and buy LM regulators from KEC. :eeh:
About the OS-Con caps in the analogal power, I will make a decision after I here the sound. However, It may take a long long time because I do not have the amp and loudspeaker yet. I make the USB-DAC, gainclone(using TDA7294 chip), and loudspeaker(using a full-range driver, Fostex FF85K) at the same time. So, there are lots of work to do. :eeh:
Using Rifa or WIMA Blackbox, it is hardly to get good answer. So, once again, whether chang it or not, I will make decision after here the sound.
Thanks your interests and suggestion. Any correspondence will be welcome. :D :D :D :D
追求極緻,絕不妥協!
如果錢夠的話....呵
Peleus
文章: 277
來自: 台灣,台北
文章Peleus 發表於 週六 6月 21, 2003 8:57 am
好像很少人說到如何測試這個USB-DAC是否可以正常工作? :eeh:
可不可以請諸位大大建議一下,如何測試這個USB-DAC?
以避免燒了機器或壞了零件的,先謝謝哦! :) :) :)
追求極緻,絕不妥協!
如果錢夠的話....呵
Peleus
文章: 277
來自: 台灣,台北
文章o~man 發表於 週一 6月 23, 2003 12:48 am
先用洞洞版搭個簡單的電路檢查四顆穩壓
穩壓ok 電容極性ok 變壓器上電ok OP方向正確
應該就沒問題了.......
超好做...... :ya:
有說跟沒說一樣 :ale:
o~man
註冊時間: 週二 3月 18, 2003 8:06 pm
正在瀏覽這個版面的使用者:Bing [Bot] 和 59 位訪客
