About UDA1341 Record and Playing?
文章cubbercn 發表於 週三 11月 15, 2006 11:24 pm
不知道简体字是否在这儿行得通?
Hello, my guys,
I have done an experiment using s3c2410 and uda1341st, but I have found the voice I had recorded was slower than the normal speed when playing. I set the IISPSR(5<<5)|(5<<0) which means 50.7M/(5+1),but many changes on this register don't work. I chose the 256fs, anyone have done these similar work can give me some advices? Thank you in advance:-)
cubbercn
註冊時間: 週三 11月 15, 2006 10:09 pm
文章cubbercn 發表於 週四 11月 16, 2006 9:17 am
simplifier Chinese is available here? is anybody can help me?
Thanks in advance:-)
cubbercn
文章Dream_Reader 發表於 週四 11月 16, 2006 7:01 pm
You should check 2410 IIS clock and DMA related setting at first.
Are you sure 2410 can support 256FS clock rate??
Dream_Reader
文章: 330
註冊時間: 週三 4月 11, 2001 4:25 am
文章cubbercn 發表於 週五 11月 17, 2006 4:09 pm
yes, I am sure 2410 can support the 256s, but now I have solved the problem by setting the IIS, and UDA1341st on 384fs(50.7MHz->16.9MHz->44.1KHz).
But it seems that there is no need to use the 16bits to sample the voice,8bits is enough??
cubbercn
文章Dream_Reader 發表於 週五 11月 17, 2006 6:19 pm
Accordingmy experiences the 8bits is enough to voice recognized when UDA1341 AGC is enable. But for best recording sound quality I suggest you set it to 16 bits mode that will get the sound more clear.
Dream_Reader
文章: 330
正在瀏覽這個版面的使用者:Google [Bot] 和 218 位訪客
