寫的真不錯!
寫的真不錯!
文章光光 發表於 週四 3月 27, 2003 9:34 am
Tube vs. solid state electronics
No one will ever settle this question, since both solutions have advantages in different areas. Either tubes or transistors can be truly excellent when the circuit is done carefully with the highest quality components available.
The best solid state circuits come close to disappearing. They tend to err in the direction of a faster, more defined, slightly less forgiving sound. The best tube designs approach perfection from the other side, with a sense of transparency and air. People consistently use the term "warmth" when describing tube sound. Tube circuits offer a wider array of options if you are trying to improve the sound, rather than just pass the signal through with no changes.
Digital designs approach the standard set by the analog solid state, but are less forgiving. A harder, closed top end feel often results from the limits set by current technology. Sense of air and soundstaging are usually somewhat compromised.
以上不知引自何處 (忘了)
反正不是偶寫的
光光
文章: 668
註冊時間: 週日 4月 29, 2001 1:51 am
文章Korping_Chang 發表於 週六 3月 29, 2003 2:56 am
將其安排在其擅長之處,應該就很不錯了:)
誰比較好?就給用家自己判斷吧:)
就是那個光~就是那個光~就是那個光~明頂~ :o
Korping_Chang
文章: 1310
註冊時間: 週四 5月 16, 2002 8:20 pm
來自: =KECES=
文章JamesT 發表於 週六 3月 29, 2003 10:54 am
引得太少了, 或者作者本來就寫得太少......
JamesT
文章: 1070
註冊時間: 週二 3月 06, 2001 10:45 pm
來自: DearHoney數位音樂工作室
正在瀏覽這個版面的使用者:沒有註冊會員 和 51 位訪客
