[ATH-CKR100評測 : 迷人的女聲, 不可多得的缺陷美]AZ耳機象牙塔
Re: [ポタフェス2014冬/鐵趴2015始動/Pioneer U-05簡評/W1000Z,ESW9LTD簡評]AZ孤
文章Atfcub 發表於 週二 12月 23, 2014 7:12 pm
hkgxt2002 寫:Little newbie pass by to try answering some questions for AZ:
In Sabre's Line-up, ESS dac chip from High to Low End should be sequenced at 9018>9016>9023
If you are a hardware geek, you should probably go for 9018's product such as mainland's Matrix X-sabre or Yulong da-8 etc,
But as an ATH fans, you should know that ATH's headphones really rely on combinations to get the "right sound" other than hyper
spec machine
Personally also agrees that Japanese machines can "match" the sound with ATH more often, Personally got a really hard way in finding the match "western" dac/amp for ath headphones
In this case, i guess you can take AZ's recommendation for U-05
PS) U-05 is currently using 2 ESS9016 chips to perform balanced input and decoding, and for pioneer other "top of the notch av amp or av dac is also using the same set up, so i guess it wont be so bad.
Your answer has helped me in deciding a choice. Actually, I had been doubting with something between spec and the true value of the product, but now this problem had been solved. So, I will pick U-05 for my DAC :)
I am building a system with a laptop as playback and U-05 as DAC. If i use USB port to input, it will be ok, isn't it?
Atfcub
文章: 14
註冊時間: 週一 12月 22, 2014 8:01 pm
文章azureimf 發表於 週二 12月 23, 2014 8:19 pm
baha9475 寫:[/url]
分享一下,新入手的好夥伴,感謝佛心的好賣家 :)
中頻飽滿,音場自然,重點是佩戴感真的很不錯!
喜歡人聲和輕鬆聽音樂的話,很推薦這副!
恭喜入手MA900! 這隻可以說是SONY當年名機MDR-F1的正統進化版
雖然解析度並不是那麼的高(相對於旗艦), 但確是隨便推都可出好聲, 音場亦寬廣自然
70mm單體下展現的三頻均衡性與動態感, 類似的聽感在Z7上也可以充分感受到
Ching-Tzun Chang
AZ象牙塔網站
sheryl.tw/aztower
azureimf
文章: 1973
註冊時間: 週三 11月 22, 2006 3:47 pm
文章azureimf 發表於 週二 12月 23, 2014 8:37 pm
Atfcub 寫:Thanks much, azureimf. I'd checked U-05's Dac chip, it still uses Sabre ES9016. Is it more different than ES9018 or ES9023 (about performance, quality) ? Do you think with the similar cost, has any others more better?
About my own headphones, i have A900xltd, the two year old M50 and maybe I will order w5000 or w1000z in the future.
But for W5000 and all AD series, U-05 is just enough (the greatest partner for W5000 is AT-HA5000)
Do you mean that combo U-05/HA5000 are the greatest choice for W5000 and AD series?
In my experience, most important issues of the sound quality is not all depend on DAC chip. Most of the time, analog electronic circuit and power supply, parts (condenser etc) and headphone amp will leads the final performance of sound. So, I do not care about the DAC chip so much but care the whole feature design of a DAC/AMP.
However, DAC chip decides the highest resolution of sound, new and flagship DAC chip provides better result of SNR and THD/IMD. and better solution of jitters. That's why I feels U-05 's resolution is higher than FOSTEX HP-A8.
For the modern period DAC, I think it should to provide a sound with high resolution sound without dyeing. However, headphone amp and headphones have their own dyeing and characteristic.
In my recent review, I feels U-05 matches W5000, but little different from the W5000 with HA5000. I can't say which one is better but they both good.
Ching-Tzun Chang
AZ象牙塔網站
sheryl.tw/aztower
azureimf
文章: 1973
文章azureimf 發表於 週二 12月 23, 2014 9:08 pm
qqkyo 寫:正如AZ大所說, 線材並不會帶來天大的差異, 看外國的測試圖亦明白換線的差距並不會很大, 小弟本身亦不發燒線材亦從未買過線材升級, 這次只是買好看的心態入Kimber線.
反覆交換測試同一首歌多次, Kimber線的確在低頻能夠潛得更深, 高頻輕微提升, 這條線的確能夠聽出分別, 不過實在分別很少.
非常不負責任的感想: Kimber Kable在手頭不緊下入手無防, 但是Z7不是什麼非常高檔的耳機價值只是5萬多羊, Cable要約一半價錢值不值真的非常個人(我自己覺得OK啦).
感謝qqkyo大的感想, 其實Z7的價格非常的實惠若這條線中古在15000日元以內, 而且擴和DAC已經搭配完美的情況下應該還是值得入手的. 有個說法是越靠近耳機單體的線越能劇烈的改變聲音
就像單體線圈的OFC7N/OFC4N能夠直接且明確的對耳機解析度造成影響, CCAW則變成完全不一樣的另一種聲音
鐵三角旗艦耳機線的PCOCC和OFC6N, 我自己感受有一點不同但並不是那麼好歸納(因為耳機本身也不同,無法直接比較)
RCA以及Line對接線, 則我自己也確能感受到差別
Ching-Tzun Chang
AZ象牙塔網站
sheryl.tw/aztower
azureimf
文章: 1973
文章KowdanL 發表於 週三 12月 24, 2014 1:10 am
最近在AA二手區收到了隻AD1000,保存狀況還算不差,感謝賣家(價錢算佛心,這隻收二手的CP值真的蠻高的)
想起來算是我收的第一隻開放式耳罩啊...
剛好當作外出用的耳機(學校宿舍),畢竟家裡那幾隻沒有刮傷,帶出門稍嫌麻煩...
聽起來聲音相當自然,不過還是聽得出有小鐵的染音
剛好當作讀書時一邊聽音樂的耳機,重量比家裡幾隻封閉式的輕不少
不過感覺耳罩有點淺,戴久了會有點痠痛
大概之後會收個AD2000X的耳罩來套看看,順便體驗不同的調音
耳罩式耳機:STAX SR-007A / SR-507 / Philips Fidelio X2 / ATH W1000 / A900XLTD
擴大機:KGSShv Carbon /w QED Reference Qundoit / STAX SRM-727A
DAC:Luxman DA-200 /w Luxman JPA-15000
壁插:CARADS 4181US
耳道式耳機:Westone W4R + 管迷QER-SE2
隨身訊源:Pioneer XDP-300R
KowdanL
文章: 85
註冊時間: 週六 10月 27, 2012 12:49 am
文章karass 發表於 週三 12月 24, 2014 2:08 am
請問一下
現在正考慮購入耳擴,看中了其中兩款
1.SONY PHA-2
2.Audio Technica pha-100
我目前組合是
SONY F886 + ATH-IM03
請問一下配哪一個比較好呢?主要是聽女聲,謝謝喔
目前看到日本pha-100 已經降到4萬多日元,比較吸引
karass
文章: 17
註冊時間: 週二 12月 23, 2014 12:33 am
文章qwerasdf856 發表於 週三 12月 24, 2014 4:40 am
z350philip 寫:想問一下換上KIMBER KABLE 的Z7表現如何
和原廠線比起來差別會很多嗎?
小弟持有Kimber Kable平衡線,個人聽感在PHA-3上和原廠線差別是明顯的,低頻收緊,聲音線條變好,不會影響到其他頻段,原廠線低頻比較大片會稍微吃到別頻,控制比較不好。另外高頻解析上升一些,原廠線相較之下比較模糊。
qwerasdf856
文章: 32
註冊時間: 週四 10月 17, 2013 4:34 pm
文章sampipsolid 發表於 週三 12月 24, 2014 10:16 am
karass 寫:請問一下
現在正考慮購入耳擴,看中了其中兩款
1.SONY PHA-2
我目前組合是
既然有F886那當然是買PHA2吧?
這樣可以走數位輸出發揮PHA2的DAC功能
音質會好上幾個檔次
sampipsolid
文章: 26
註冊時間: 週三 12月 19, 2007 12:40 am
來自: 火星
文章willy340 發表於 週三 12月 24, 2014 11:24 am
azureimf 寫:
baha9475 寫:[/url]
喜歡人聲和輕鬆聽音樂的話,很推薦這副!
我也有MA900,确实怎么推都出好声,音场超大,但是有点空的感觉
AZ大,我想说本来应您的推荐要入ESW9LTD的,发现大陆价格竟然不是预售价无耻涨价了,涨的还有点多
于是现在考虑是否将本来也有点心动的im02改为您推荐的ckr9ltd,
有疑惑是不是CKR9LTD有点闷啊...我看大陆的听感说比r10还闷...
我比较喜欢三频稍微均衡,通透中频带有一点韵味的风格,主听日系女声
AZ大应该会入r9ltd来当动圈主力塞吧?那什么时候评测啊,期待~~ :worship:
willy340
註冊時間: 週日 12月 07, 2014 12:37 am
文章KowdanL 發表於 週三 12月 24, 2014 12:34 pm
想問一下,像是Pioneer U-05這台的XLR平衡頭
可以用Z7的3.5平衡線轉XLR平衡來聽嗎?
不知道這樣能不能有平衡的大音場,又不用買PHA-3來專推Z7
壁插:CARADS 4181US
KowdanL
文章: 85
文章hotdogII 發表於 週三 12月 24, 2014 12:45 pm
z350philip 寫:...
接行動裝置的話偶而會這樣(PHA-2和PHA-3都會,是不是熱機問題我也不是很清楚)
所以我覺得是SONY行動裝置(不管手機還WALKMAN)的問題
謝謝z350大的答覆...
sony walkman-a15/17有發布新韌體更新,
小弟也更新了,
再持續觀察一下...
耳罩式耳機:SONY MDR-Z7、Beyerdynamic T1 2nd,SONY MDR-MA900
耳道式耳機:InEar SD-3
隨身訊源:SONY WALKMAN-A17
隨身耳擴:SONY PHA-3
家用訊源:PC with JPLAY
家用一體機:TEAC UD-503
家用耳擴:WOOAUDIO wa22
hotdogII
文章: 18
註冊時間: 週一 12月 22, 2014 11:37 pm
文章karass 發表於 週三 12月 24, 2014 3:04 pm
sampipsolid 寫:
karass 寫:請問一下
現在正考慮購入耳擴,看中了其中兩款
1.SONY PHA-2
我目前組合是
既然有F886那當然是買PHA2吧?
音質會好上幾個檔次
鐵三角的pha-100 也有DAC功能
加上自家的耳機應該有加成吧?
不過問題是網上對pha-100評測太小了,無法參考 :aa:
karass
文章: 17
文章suzumiyaminami 發表於 週三 12月 24, 2014 3:50 pm
KowdanL 寫:想問一下,像是Pioneer U-05這台的XLR平衡頭
可以的,但是效果和PHA-3推出來的哪個比較好聽還有待有人檢驗。
System :
PHA-3+SONY MDR-Z7
JVC FXD70/IM03/Z1070
for Anime & Music & Galgame
他人に悪意を向いたらいつか自分の元に返すだけだ。
suzumiyaminami
文章: 542
註冊時間: 週二 3月 11, 2008 5:57 pm
來自: 逢甲
文章suzumiyaminami 發表於 週三 12月 24, 2014 3:52 pm
karass 寫:請問一下
現在正考慮購入耳擴,看中了其中兩款
1.SONY PHA-2
我目前組合是
im03這種耳道反而不需要太推力,個人覺得拋了f886,轉購入a10系列(例如a16),
會是更經濟實惠的有效升級方式。
pha-2的聲音非常染非常濃,個人覺得和本身就有染色的im03不太搭。
System :
PHA-3+SONY MDR-Z7
suzumiyaminami
文章: 542
來自: 逢甲
文章Atfcub 發表於 週三 12月 24, 2014 5:18 pm
azureimf 寫:In my experience, most important issues of the sound quality is not all depend on DAC chip. Most of the time, analog electronic circuit and power supply, parts (condenser etc) and headphone amp will leads the final performance of sound. So, I do not care about the DAC chip so much but care the whole feature design of a DAC/AMP.
Yup, I like the neutral DAC ,too.
Is that so, I thought you mean U-05 as DAC and HA5000 as amp.
Atfcub
文章: 14
文章hiiragiyukari 發表於 週三 12月 24, 2014 6:28 pm
Atfcub 寫:
azureimf 寫:
Atfcub 寫:大家好,我是一个外籍院士(ATH风扇的男孩),我不知道中国人,所以我必须使用谷歌翻译进行沟通。我想买一个DAC和蒂雅克UD-501,先锋U-05和音频-GD NFB1(2015年版本)之间的怀疑。我喜欢的声音清晰,细节,真实的,平衡的和宽敞的,SS,可与放大器,如ha22tube......哪个是更好的搭配都非常好?
Nice to meet you, Atfcub
You can feel free to talk here in English (if you prefer, you can also post in Japanese)
If you like clear sound with more details, I think TEAC UD-501 and Pioneer U-05 are both good choices. They both have perfect sound performance, solidity sound field, and less dyeing
Actually, U-05 is the newest one, more technology (audio DSP and digital filters) and a balance headphone amp are combined on it. So I will suggest you to buy U-05 at now.
For AT-HA22tube, it’s also a good tube headphone amp but depends on your own headphones
If you have W3000ANV, W1000Z, W1000X, A900XLTD (for W1000, I am not sure), I would strongly suggest you to buy it. In other word it might means “necessary”. But for W5000 and all AD series, U-05 is just enough (the greatest partner for W5000 is AT-HA5000)
Hi,Atfcub
What style of music is your favorite? (Ex:Classic,Jazz,ACG...etc)
It can let us know your requirement and take more suitably suggestion for you.
hiiragiyukari
文章: 64
註冊時間: 週二 12月 16, 2014 9:15 pm
文章NightKirie 發表於 週三 12月 24, 2014 7:00 pm
azureimf 寫:
NightKirie 寫:AZ大您好~
我是AA新手
目前有A900XLTD 主聽女聲ACG
之後會去日本 想買隨身播放器跟耳道式耳機
之前有聽過FIIO X3 覺得還不錯
耳道式只有聽IM03跟SE535(好像是這支) 但都沒很喜歡
想請問哪一支耳道聲音走向比較像A900XLTD?
預算約50000日幣(隨身播放器+耳機)
是想買FIIO X3+FIIO E12(可有可無) +耳道式耳機這樣搭配
如果隨身播放器有更好的搭配 麻煩給我其他建議
謝謝!
Fiio X3推A900XLTD可以展現出基礎素質, 但若再搭配Fiio E12則效果會更好, 缺點就是綁炸彈了
目前走向非常類似A900XLTD的耳道就是CKR9LTD, 連顏色也都一樣. 個人非常建議購入這支
撥放器若手上還沒被綁住的話可以多家試聽, 總預算五萬扣掉CKR9LTD三萬日幣剩下兩萬
兩萬選播放器還真的只有SONY NW-A16和Fiio X3可以選了, 當然X3可以在台灣買就好
若以升級性,萬用性來考量的話X3是個好選擇. 只是其播放操作介面真的很貧弱, 是必須妥協的地方
再問幾個問題
目前家用配備是JRiver-->JPlay-->AUNE T1 TUBE(原廠管)-->A900XLTD
聽別人說T1不適合聽女聲 會抹煞掉鐵家調性
但我自己聽是還好 管子是想等原廠管壞掉再換Tesla E88CC code37
還是不要換 繼續存換更好的DAC+擴?
還有我看e☆イヤホン 在上野公園附近...剛好會去(FUJIYA AVIC的比較貴?)
FIIO X3賣22060日幣 FIIO E12賣11340日幣
如果不買E12 預算還有27940日幣 +E12只剩下16600日幣
大概這兩個價位 有哪隻比較推薦的耳道?
f0ae7ade
最後由 NightKirie 於 週三 1月 14, 2015 11:49 pm 編輯,總共編輯了 2 次。
耳罩式耳機:DT880pro 250ohm
耳道式耳機:BFD 四單+RSD Golden MKIII
家用訊源:暫定WADIA
隨身訊源:暫無
NightKirie
註冊時間: 週日 7月 06, 2014 10:29 pm
文章Atfcub 發表於 週三 12月 24, 2014 7:16 pm
hiiragiyukari 寫:Hi,Atfcub
Actually, I listen many kinds of music such as Pop, vocal, rock ballad, instrumental,trailer epic... but rock ,metal, edm DJ.
Atfcub
文章: 14
文章karass 發表於 週三 12月 24, 2014 7:34 pm
suzumiyaminami 寫:
karass 寫:請問一下
現在正考慮購入耳擴,看中了其中兩款
1.SONY PHA-2
我目前組合是
會是更經濟實惠的有效升級方式。
A10系列好像與F886分別不大
如果升級前端是否會比耳擴好一些?
F886 --> ZX1 ?
還是建議換耳機?
karass
文章: 17
文章suzumiyaminami 發表於 週三 12月 24, 2014 8:05 pm
karass 寫:A10系列好像與F886分別不大
如果升級前端是否會比耳擴好一些?
F886 --> ZX1 ?
還是建議換耳機?
個人是覺得f系列的walkman調音很糟糕,特別f880是最糟糕的,
聲音雖然高解析但是中頻凹陷聽起來機械不自然,音染很怪。
您可以爬爬看象牙塔內az大也是同樣給與地雷評價。
a10的話調音則是介於f880和溫潤的z1070直接兼具f880的解析,
然後一些設計上是全新的(沒有在f880搭載),有些則是換成向zx1看齊的零件。詳細技術內容我就不翻譯了。
http://www.phileweb.com/news/d-av/201409/25/35630.html
音質上雖然不會超越zx1但是不論是價格上,microsd具備的擴充性,還有輕薄攜帶性上,構成一個很不錯的產品定位。
如果考慮zx1不如緩緩,因為zx2 大概在1月多就會發表了,也就是2015 ces。
當然,換耳機所帶來的聽感改變會很大,但是我個人是極度建議趕快換掉f880。
差點忘了,若您預算充足可以考慮購買TEAC或是ONKYO的隨身一體機。
System :
PHA-3+SONY MDR-Z7
suzumiyaminami
文章: 542
來自: 逢甲
文章azureimf 發表於 週三 12月 24, 2014 10:10 pm
如果升級前端是否會比耳擴好一些?
F886 --> ZX1 ?
還是建議換耳機?
F880與A10系列只看官方規格當然不會覺得有什麼差別
F880與A10系列我都多次實際試聽,如同suzumiyaminami版主所說
F880的調音為了與ZX1產生區隔, 採用了過度強調低高音,中頻凹陷且機械的調音手法
這種聲音配上低階耳機乍聽很爽, 但長久的聆聽經驗與品味下來會發現其實缺點畢露
反過來A10雖然推力略小, 但還維持了往年Walkman應有的調音水準. 加上可以插卡
若以推動耳道為主, 算是我近期推薦的選擇(推動大型耳罩, 推力不足聲音表現會偏平面,缺乏動態感音場也拉不開, 以往的A840/A850也都有類似的問題)
當然, A10的整體表現完整度確不如ZX1, 目前ZX1是Walkman中音樂性,音響性尚符其實的旗艦
IM03拿大推力的隨身擴推只會更加破壞平衡性, 效果通常都不會好
IM03同樣調音走向若要升級, 恐怕只有價錢貴上5倍的Fitear眾旗艦可選, 或是1964V6的非低頻加強版
Ching-Tzun Chang
AZ象牙塔網站
sheryl.tw/aztower
azureimf
文章: 1973
文章azureimf 發表於 週三 12月 24, 2014 10:16 pm
NightKirie 寫:再問幾個問題
還是不要換 繼續存換更好的DAC+擴?
大概這兩個價位 有哪隻比較推薦的耳道?
我只在象牙塔家聚中聽過一次AUNE T1, 當時搭配的是AD1000PRM與W1000
我覺得聲音頗為直白大推力, 沒有明顯的韻味, 配上W1000過於刺亮且偏薄, 配上AD1000PRM則尚可
我覺得AUNE T1並沒有過多的管味(AUNE T1那一根真空管是整流管而不是放大管, 放大管的話最少要L/R兩跟)
整流管改善的是電流供給, 相對放大電路對於聲音的染色有限
我是認為A900XLTD搭配的適合管擴仍為原廠的HA22TUBE, 音響性上並無明顯的減損,也無可辨別的底噪
音染上HA22TUBE對於中頻與高頻有輕中度的染色, 與A900XLTD/W3000ANV的搭配性非常的好
Fiio E12整體素質在同價位隨身擴中屬於極優秀等級, 但整體音響性不及HA22TUBE
Ching-Tzun Chang
AZ象牙塔網站
sheryl.tw/aztower
azureimf
文章: 1973
文章azureimf 發表於 週三 12月 24, 2014 10:22 pm
KowdanL 寫:最近在AA二手區收到了隻AD1000,保存狀況還算不差,感謝賣家(價錢算佛心,這隻收二手的CP值真的蠻高的)
不過感覺耳罩有點淺,戴久了會有點痠痛
AD1000一直以來都是我難以忘懷, 也是我現役耳機中被我當作Reference Headphone的耳機
中高頻有著鐵三角最引以自豪, 透明輕亮, 瑞而不刺的極優秀高頻表現. 而扣除低頻不夠的問題外整體解析度可以說奠定了往後1000番台的基礎, 即使如W1000Z我仍認為解析度對上AD1000並沒有太大贏面
耳罩淺的問題是無解, 這就是AD1000聲音的代價
往裡面墊衛生紙會改變調音, 換上HP-AD2000X聲音會變的立體,中頻變的更暖但是高頻的延伸與透明感會被抑制. 算是AD1000的另一種型態
Ching-Tzun Chang
AZ象牙塔網站
sheryl.tw/aztower
azureimf
文章: 1973
文章Atfcub 發表於 週三 12月 24, 2014 10:23 pm
azureimf 寫:我只在象牙塔家聚中聽過一次AUNE T1, 當時搭配的是AD1000PRM與W1000
Have you ever tried to change the tube stock of Ha22tube by others?
Atfcub
文章: 14
文章karass 發表於 週四 12月 25, 2014 12:10 am
azureimf 寫:
如果升級前端是否會比耳擴好一些?
F886 --> ZX1 ?
還是建議換耳機?
如果換了A16後是否已經足夠了?
請問還需要購入耳擴嗎?
karass
文章: 17
正在瀏覽這個版面的使用者:Bing [Bot], MorrissLom 和 219 位訪客
