COWON D2 韌體3.41正式版釋出了
文章lls613 發表於 週一 3月 26, 2007 7:28 pm
COWON D2 韌體3.41正式版釋出了,早上在大陸iaudio網站看到,但一直進不去,剛剛去看,確定是正式版 :bs:
下載點:http://download.cowon.com/data/C08/D2_3.41.zip
因為是寫韓文,所以目前不知道修正了什麼bug :ale:
http://board.cowon.com/zeroboard/zboard.php?id=C08&category=&no=392&bmenu=C&category=38
剛剛用翻譯網站翻了一下,結果是...慘不忍睹 :mad:
SD卡插入小時[事]速度改善
-最大文件公認[kays]增量
-它記錄或telerecording的質量改進
- SD卡片大文件營業時間音樂圖書館錯誤現實情況校正
- DMB海峽徵兆錯誤校正
-電子詞典功能安定
-文本[pyu] [e] [yu] [ni]繩子加法(UTF-8和UTF-16)
-北部標記指定錯誤校正
-其他功能安定
*最大文件公認[kays] : 共計6,000 (3,000內臟記憶3,000 +主體外部記憶)
補上英文...
- SD card insertions hour thing speed improvement
- the maximum file recognition Gaes possibility increase
- sound recording/telerecording quality improvement
- SD card massive file store hour myu Jig library error actual condition amendment
- DMB Channel indication error correction
- electronic dictionary function stabilization
- text pyu U Yoo ni cord addition (UTF-8, UTF-16)
- north mark designation error correction
- other function stabilization
The maximum file recognition Gaes possibility: Total 6,000 things (3,000 internal organs memories 3,000 + outside market memories)
---------------我是分隔線-----------------------
補上美版的(應該是吧),版本是2.41正式版:
http://www.cowonglobal.com/download/file/cowon_program/cowond2_firm/D2_2.41.zip
修正內容如下: (中文是用翻譯網站翻的 :ale: )
http://www.cowonglobal.com/zeroboard/zb ... u=download
- Support the integrated browser “Music Library” (File Browser & Music Brower)
- Support lager SDHC memory cards
- Added the function to set Hold State
- Added the function of Virtual Motion UI
- Support MTP/WMDRM 10
- Added the function to view the freeze-frame of a movie file
- Improved FM reception
- Delete movie shuffle mode
- Fixed the error when playing the file in Record mode
- Fixed the error to delete files
- Stabilized the firmware
- Fixed the error that does not recognize Digiworks MLC SD cards
- Fixed the error that does not read FLAC files
- Improved booting speed
- Fixed the error that does not read OGG tags
- Stabilized Music library function
- Fixed the error of text bookmark
- Added the function to arrange songs when adding songs to the Dynamic Play List folder
- Improved the booting speed when inserting a SD card
- Improved the maximum number of files (internal memory:3000+external memory:3000)
- Improved the recording quality
- Fixed the error of Music library if there are many files in a SD card
- Support Text viewer Unicode (UTF-8, UTF-16)
- Fixed the error of bookmark
- Stabilized other functions
- Fixed other bugs
- 支持聯合瀏覽器"音樂圖書館" (文件瀏覽器& 音樂Brower)
- 支持貯藏啤酒SDHC 存儲卡
- 增加了作用來集合舉行狀態- 增加了真正行動UI 的作用
- 支持MTP/WMDRM 10
- 增加作用觀看靜止畫面電影文件
- 改善的FM 招待會
- 刪除電影拖曳方式
- 改正了錯誤當演奏文件在記錄方式下
- 改正錯誤刪除文件
- 穩定了固件
- 改正了不認可Digiworks MLC SD 卡片
- 的錯誤改正了不讀FLAC 文件
- 的錯誤被改進解雇速度
- 改正了不讀OGG 的錯誤標記
- 被穩定的音樂圖書館作用
- 改正了文本書簽錯誤
- 增加作用安排歌曲當增加歌曲來動態戲劇名單文件夾
- 改進了孕穗速度當插入SD 卡片
- 改進了文件(內部memory:3000+external 的最大數字memory:3000)
- 改進了錄音質量
- 改正了音樂圖書館錯誤如果有釵h文件在SD 卡片
- 支持文本觀察者Unicode (UTF-8, UTF-16)
- 改正了書簽錯誤
- 穩定了其它作用
- 修理了其它臭蟲
最後由 lls613 於 週二 3月 27, 2007 8:03 pm 編輯,總共編輯了 2 次。
lls613
註冊時間: 週六 5月 06, 2006 7:48 pm
文章犬爸 發表於 週一 3月 26, 2007 8:25 pm
謝謝分享喔! :)
這應該是韓版的 Firmware
犬爸還是比較想等美國的 Firmware出在更新嚕
不過美版的 Firmware現在還是 2.20 stable...
真是慢啊… :x
Dog-Pa U.S.A. Agency
犬爸美國精品代購
【體力 HP】:iAUDIO I7 4GB
【法力 MP】:Sony EX90LP
【經驗值 EXP】:∞ → infinite
犬爸
註冊時間: 週四 1月 25, 2007 4:16 pm
來自: 犬爸的狗窩
文章lls613 發表於 週一 3月 26, 2007 9:15 pm
請問,韓版和美版的韌體差異性是...?
lls613
文章犬爸 發表於 週一 3月 26, 2007 10:03 pm
lls613 寫:請問,韓版和美版的韌體差異性是...?
簡單來說…犬爸也不知道… :ho:
不過因為犬爸的機子是在北美購買的,
所以還是想等美國釋出美版的韌體才做更新嚕
不過已經有很多論壇的朋友都升級至 3.41版了說…
犬爸也很心動嚕… :oops:
犬爸美國精品代購
【法力 MP】:Sony EX90LP
犬爸
來自: 犬爸的狗窩
文章lls613 發表於 週一 3月 26, 2007 10:22 pm
謝謝犬爸的回答,原來是個人喜好,我還以為有什麼不同呢 :ya:
lls613
文章chenchen 發表於 週二 3月 27, 2007 9:27 am
我的D2是跟犬爸購買的美版,
目前也更新3.41正常使用中。
另外"個人感覺"更新後音量可以比以前開小2級,
相信這樣電力可以維持更久,
(之前音量開10級 flac+ape+mp3 連續播放最長30小時)
並且配合之前犬爸分享的字典檔,
英英字典也可以正常使用。
chenchen
註冊時間: 週二 1月 16, 2007 8:47 pm
文章犬爸 發表於 週二 3月 27, 2007 12:14 pm
chenchen 寫:我的D2是跟犬爸購買的美版,
目前也更新3.41正常使用中。
相信這樣電力可以維持更久,
並且配合之前犬爸分享的字典檔,
英英字典也可以正常使用。
PowerDic 字典檔不錯用吧! :D
不過犬爸手機已經有英英字典嚕,
不然應該也會狠給他灌下去吧∼ ;)
犬爸美國精品代購
【法力 MP】:Sony EX90LP
犬爸
來自: 犬爸的狗窩
文章使魔凱特 發表於 週二 3月 27, 2007 3:26 pm
剛剛更新了!( 2.41b→3.41)
目前一切正常 :D
使魔凱特
文章: 50
註冊時間: 週三 11月 21, 2001 3:18 pm
來自: North Taiwan
文章lu7371 發表於 週二 3月 27, 2007 4:35 pm
犬爸 寫:
目前也更新3.41正常使用中。
相信這樣電力可以維持更久,
並且配合之前犬爸分享的字典檔,
英英字典也可以正常使用。
不過犬爸手機已經有英英字典嚕,
不然應該也會狠給他灌下去吧∼ ;)
請問犬爸英英字典要怎麼灌阿? 目前只有多了ICON
家用 1793 > 大極典A4
外出W902 >狗骨頭 > Igrado
精簡系統中.....
lu7371
註冊時間: 週日 4月 24, 2005 10:27 pm
來自: 烘爐地下南勢角
文章lls613 發表於 週二 3月 27, 2007 8:05 pm
在cowonglobal又出了一個韌體版本2.41正式版...
上面內容已經更新了。
lls613
文章kasy 發表於 週二 3月 27, 2007 9:18 pm
請問各位韓版比較好還是美版
好難決定耶
kasy
註冊時間: 週二 3月 27, 2007 9:16 pm
文章lls613 發表於 週二 3月 27, 2007 9:51 pm
剛才有稍微查詢一下,2.41是3.41的無字典版,其他應該沒有差別。
lls613
文章犬爸 發表於 週二 3月 27, 2007 10:09 pm
lu7371 寫:
犬爸 寫:
目前也更新3.41正常使用中。
相信這樣電力可以維持更久,
並且配合之前犬爸分享的字典檔,
英英字典也可以正常使用。
不過犬爸手機已經有英英字典嚕,
不然應該也會狠給他灌下去吧∼ ;)
如果犬爸記的沒錯,應該是要韓版韌體 3.40以上的才有支援 PowerDic喔∼ :)
犬爸美國精品代購
【法力 MP】:Sony EX90LP
犬爸
來自: 犬爸的狗窩
文章閒雲羅 發表於 週二 3月 27, 2007 11:35 pm
已經更新了。
感覺上穩定多了。
那個字典也超好用的。
只是不知道檔案太多的話,是否會如2.41b的問題,無法正常讀取。
音響(CEC 3300R,X5L)-dared 2A3C-JB4MKII
家用耳機(Rio Karma)-平衡版MPA2.5-(A950Ltd,KK)
外出耳機(iAudio D2,U3)-(EW9,CM7Ti)
閒雲羅
註冊時間: 週五 1月 27, 2006 11:58 pm
文章mitwhk 發表於 週三 3月 28, 2007 4:12 am
終於有正式版嚕
來更新去 :ya:
MP3: iAudio A2, D2 Sony N10
Earphone: Shure E4G
Wanna purchase: Westone UM2
mitwhk
註冊時間: 週日 4月 10, 2005 3:49 am
文章lu7371 發表於 週三 3月 28, 2007 10:25 am
犬爸 寫:如果犬爸記的沒錯,應該是要韓版韌體 3.40以上的才有支援 PowerDic喔∼ :)
是阿,我是灌韓版3.41 可是只有MENU多了一個ICON,點進去說ACCESS TO FONT FAILED
不知道要怎樣才有英英字典?
家用 1793 > 大極典A4
精簡系統中.....
lu7371
來自: 烘爐地下南勢角
文章chenchen 發表於 週三 3月 28, 2007 10:51 am
lu7371 寫:是阿,我是灌韓版3.41 可是只有MENU多了一個ICON,點進去說ACCESS TO FONT FAILED
不知道要怎樣才有英英字典?
去下面這篇討論串中找犬爸分享的字典檔下載網址
"急問 有在iAudio D2 使用 v3.41 Firmware 字典的朋友"
解壓縮後把PowerDic資料夾中對應的檔案傳到D2中的PowerDic資料夾裡
之後就可以正常使用了
chenchen
文章lu7371 發表於 週五 3月 30, 2007 11:42 am
chenchen 寫:去下面這篇討論串中找犬爸分享的字典檔下載網址
之後就可以正常使用了
成功了,萬分感謝~
還有個小問題就是可以只灌英英字典嗎? 找不到只有英英字典部分的POWERDIC :oops:
家用 1793 > 大極典A4
精簡系統中.....
lu7371
來自: 烘爐地下南勢角
正在瀏覽這個版面的使用者:沒有註冊會員 和 205 位訪客
