[有圖]RSA 新隨身耳放--The Predator,Portable Headphone Amp/USB DAC C
文章williamchc 發表於 週五 10月 26, 2007 11:50 pm
轉自headfi:http://www.head-fi.org/forums/showthread.php?t=267640
Dear friends & head-fiers....
As every year around this time, close to the Holidays, we at Ray Samuels Audio, release a new product & give the head-fiers the first choice of purchasing these products at special price for a limited time.
We are very pleased to inform you that the Predator, portable headphone Amp/Dac combo, is nearing it's completion, as all pc brds are manufactured.
The Predator's both pc brds, the amp & the USB, are mil specs grade with 4 oz oxygen free copper. All resistors are that of high quality Dale Vishay SMDs.
The Caps are the highest quality film caps by Panasonic. The power lanes & signal lanes are separated from each others with ground lanes & blocks of ground sections to minimize the floor noise.
You should hear no noise or hiss at all from the DAC when connected to your computer, it is completely silent in every sense no matter which headphones you use, including all the sensitive headphones, IEM, with full gain of 11, at MAX volume..
That by itself is just a remarkable accomplishment when comparing amps with each others using IEM's.
The amp section has identical parts when it comes to quality; no corners have been cut, as the Predator has the lowest noise specs than that of the Hornet & Tomahawk.
The Predator has 3 position gain switch, low, gain of One, medium, gain of Four & high, gain of Eleven. These gain setting come very handy when variety of phones are used with different impedances.
The USB/Source switch is located on the face plate, it selects between a mini stereo input source and the USB input. When the amp is used with an external source, the USB circuitry is completely disconnected from that of the amp as if it never exists and no battery power is going through it.
The Predator can play while it is charging, with no loss of sound quality. The charging time is within 2-3 hours, the play time is 7 days at 8 hours per day, per charge. The Lithium Ion battery in the Predator is good for over 500 times charging. This means 500X7 days with each charge at 8 hours per day comes to 3500 days at 8 hours per day. 3500 divided by 365 days per year = 9.6 years. That is how long the battery should last.
We are working on the chassis at mean time as the extrusion is in the work, 3 more weeks according to the extrusion manufacturer, the first chassis hopefully will be available.
The size of the Predator is going to be smaller than the Hornet bigger than the Tomahawk, right in between. The gain switch, the DC input & USB input will be at the back panel, no thumb nuts will be at the back panel as we won't be using any changeable batteries, so the look will be more like front face style.
We are doing our best to get the predator by the Holidays, hoping we can meat the dead line.
We will post later the price, the color options & take your orders.
Please do not ask for any other info now as we are trying to keep up with the rest of our work.
The Predator will be at the Florida meet next week-end, New York meet & Chicago last.
Ray Samuels
哇.看來底噪控制得超好啊,就算是用3210都不怕了 :ya:
williamchc
註冊時間: 週三 8月 01, 2007 10:50 pm
來自: Hong Kong
文章williamchc 發表於 週六 10月 27, 2007 12:07 am
我來大約總結一下
1. 強勁底噪控制,在開到最大聲,GAIN=11的狀態下,用IEM(應該是RAY的UE10)聽不出任何底噪,底噪控制比Hornet & Tomahawk更好
2. 3個增益,分別是1,4,11
3. 充電時不影響音質
4. 只需2-3小時的充電,就能有一星期7天,每天8小時的播放時間
5. 電池在500次充電後仍能維持良好的效能
6. 體積比Tomahawk大,但比Hornet 小
williamchc
來自: Hong Kong
文章HarryPotter 發表於 週六 10月 27, 2007 1:04 pm
感覺相當不錯,不知道價錢多少.
假如價錢不錯的話.這樣Corda Move可能就完全被打死了
不過RSA都走高價取向.
不過他的機器都做的好小一台...完全0負擔...
HarryPotter
註冊時間: 週六 10月 13, 2007 2:21 pm
正在瀏覽這個版面的使用者:沒有註冊會員 和 134 位訪客
