在市面上好像有兩種級距
一種是 XRCD
另一種是標示了同為 JVC K2 20bit Super Coding 技術的 logo
但卻不說自己是 XRCD
兩者價格差了一截 類型也有區別
前者常常要上千元 多古典樂
後者大概和一般唱片等價 多流行樂
當然 兩者的最終產物都是給傳統 CDP 播放的規格
我實在不解兩者的區別 本是同根生 相差何太貴
煩請高人開惑
版主: devilhades
DAC 寫:國內唱片倒是頗能臉不紅氣不喘地打上 XRCD 招牌
蔡阿姨等等都有長銷的 XRCD 版本
這是全套還是半套?
聽起來… 嗯… 我的器材不夠好吧![]()
如版主大人所說全套只在自家做的話
不就得把母盤送到 JVC 橫濱廠
把蔡阿姨母盤長途運送會讓許多人擔心飯碗吧…
頂多也只能送個不知品質如何的 copy愈想愈偏了
Argerich 寫:DAC 寫:國內唱片倒是頗能臉不紅氣不喘地打上 XRCD 招牌
蔡阿姨等等都有長銷的 XRCD 版本
這是全套還是半套?
如版主大人所說全套只在自家做的話
不就得把母盤送到 JVC 橫濱廠
JVC的網頁 http://www.xrcd.net/shopping/process.asp
上面有一些描述可以讓大家對於XRCD有更進一步的認識∼![]()
In most cases, after a record has been mastered, a U-matic 1630 format tape is prepared and shipped to the manufacturing plant. At this point the artist, producer, and engineers can only hope that their work will return to them in a relatively unchanged form. This manufacturing chain is not standardized, and while digitally correct, does not always reproduce the highest audio quality possible. Since the manufacturing process works as a number of components linked together in series, the overall performance can only be limited by each stage. This means that extreme care and attention must be paid to every aspect of mastering and manufacturing to get the most out of the process.
JVC has painstakingly gone through every step of the mastering and manufacturing process with the goal of retaining the highest sonic purity of the original music. This was accomplished not by just measuring the results, but in extensive listening tests to determine the best configuration. Every combination of equipment, connections , AC power regulation, word clock distribution, mastering format, delivery system and compact disc construction was tested. The results is the xrcd, a compact disc that offers clearer definition, more accurate imaging, and higher audio quality than any compact disc before.
內容大概強調從頭到尾,單一生產製造過程,掌控許多環節,以達到最高品質,
並且有和母帶比較聲音的測試,來取得最佳化設定。![]()
XRCD的製作確實比起一般CD來得嚴謹考究∼理論上應該更接近原始母帶的效果。
然而結果是能否聽得出差別?聲音的風格是否能被接受?以聲論價,真的值得嗎?![]()
小弟我想每個人的觀點不盡相同!
正在瀏覽這個版面的使用者:沒有註冊會員 和 47 位訪客
